To read the meter, take the reading and multiply it by the scale setting. 0.22 times 20ma equals 4.4ma. Be sure you have the meter set property. Most meters require one probe plug to be moved to the Amp or Ma socket of the meter to read amps.
So, the meter would have one probe (red/positive) plugged into the V/ohm socket The other (black/negative) would be moved to the Amp or Ma socket.
Check you meter as it may be different then the above setups.
There also could be 20ma/10A meter setting. This means the meter will read down to 20ma when the probe is plugged into the ma socket and up to 10A when plugged into the 10A socket.
I state this because if the battery is still loosing charge (and is new), it must be loosing it through the cables. The meter has to pickup this current flow.
Check the link below for battery voltage versus percentage charge of battery.
http://en.wikipedia.org/wiki/Car_battery
The voltages are a little lower then I stated but you will see the difference between fully charged and 0% charge is not that large.
Don't let the battery go completely dead as this will shorten its life. If it keeps dropping start the car and recharge it..
