07 Yaris Hatchback Question? what size are the stock wheels and offset? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2007, 09:52 PM   #1 (permalink)
Owners of a Solara & Vitz
iTrader Score: 6 reviews
View CDNVITZ's Photo Gallery
07 Yaris hatchback RS Question? What is the stock offset and what is the width of the stock rims 15 x 5, 5.5 6, 6.5?
I have a deal going where I'm about to purchase Tom's wheels size is 15 x 7 +45 offset.
Wondering if they will fit without a problem on the car.
Thanks for your help in advance guys!
btw mine is a RS model....
-Rick
2007 Vitz RS
CDNVITZ is offline   Reply With Quote
Old 01-19-2007, 07:55 PM   #2 (permalink)
9 peeps has saw this post but no one knows the answer... don't be shy...
I was told on another site that the size is 15 x 5 and a +38 offset... just want to see if this is right..
-Rick
2007 Vitz RS
Old 01-20-2007, 01:55 AM   #3 (permalink)
View rice's Photo Gallery
^maybe they dont know the answer? ^_^
+45 should be fine
the RS is the highest model, right? if so, 15 x 5.5-6.0 sounds about right
rice is offline   Reply With Quote
Old 01-20-2007, 11:26 AM   #4 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
Wish I could help. The echo will mount a 6 with not too many issues depending on the tire size, but an echo isn't a yaris.
Old 01-24-2007, 02:29 PM   #5 (permalink)
3cyltrbo's Avatar
View 3cyltrbo's Photo Gallery
-Rick
here is your answer:
15x7 is a bit wide / and 45 is a pretty high offset / depending on the size of the tire, you won't be able to achieve full lock and you will certainly rub over bumps.
As you may not know, the higher the offset - the higher the back side of the wheel is from the hub face (effectively tucking the wheel further into the wheel well) although this is normally a good thing, in this case it will come down to the size of tire you use, simply because 15x7 is a bit wide. Too big will rub at inner spots of the wheel wells and potentially rub on the fenders (especially the rear). I wouldn't go wider than 205 or taller than 50 (technically speaking 205/50/15 is the equivalent rolling diameter to the stock size)
Lowering will exaggerate this problem, so do not expect to also have an aggressive drop.
Mine is lowered approx 2 inches and I run a 15x6.5 42mm with 195/50/15s and even my car rubs in certain corners with full load.
BTW on a side note, my lowly Echo went on to do very well in shows through 2005 and even won the Rolla/Camry/Solara/Echo class at NOPI NY 2006
Have a great day
3cyltrbo is offline   Reply With Quote
Old 01-26-2007, 11:51 PM   #6 (permalink)
View tekmoe's Photo Gallery
with convenience package, the stock wheel size is 15x5.5 i believe. the tires are 185/60/15.
tekmoe is offline   Reply With Quote
Old 01-27-2007, 09:18 PM   #7 (permalink)
View Pars's Photo Gallery
Hopefully the 07 Yaris is not as picky with the wheel's offset as the older Echo. But considering that the tinny stock wheels are already near to the very edge of the wheel well, there's probably not much room to play with, for s wider setup. I was considering going with 7' rims, but after reading this post, I think I'll keep it down to 6.5' width on 15' rims and 195/55/15 tires. In which case, would the better offset be, 40mm or 42mm? (for a 07 Yaris).
Pars is offline   Reply With Quote
Question on new wheels for '07 camry simplyxtrippin 5th & 6th Generation (2002-2006 & 2007-2011) 4 07-05-2006 08:22 PM
Ordering New Wheels, quick question. BruynBoy 2nd Generation (2005+) 5 02-27-2006 06:51 PM
offset of 14x6 stock wheels iamsupraman Pre-88 Toyota Pickup/Hilux 0 02-23-2006 05:18 PM
Stock Wheel size Waterwookiee 2nd Generation (2005+) 6 12-05-2005 02:53 PM
question about wheels and offset numbers dmem1 1st Generation (1995-1999) 7 08-26-2005 08:23 PM
