07 Yaris manual transmission adjust? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2007, 09:45 AM   #1 (permalink)
View bcudone's Photo Gallery
I have a new 07 hatchback with manual 5 speed. I find the lower shifting to be very loose (compared to my 1998 VW bug). Has anyone else noticed this? Is there an adjustment I can have the dealer make?
bcudone is offline   Reply With Quote
Old 01-27-2007, 08:56 PM   #2 (permalink)
View Pars's Photo Gallery
'loose lower shifting', what's that? I suppose the shifter can get loose if someone was abusing the stick. If there's a experience driver behind the wheels, the stick ususally doesn't get abused and will always feel as tight as a Vergin.
The only thing I know of that'll change the shift action and also tighten up a loose and worn-out shifter is a short-shift kit. Personally, I think shorter shifts would be nice, especially considering that longer shifts in the Yaris isn't that smooth (but till good). So, if it's going to be slightly notchy anyways, might as well go with the shorter shifts. But, with the shorter shifts, you need shorter clutch travel to balance it out, e.g. the Celica GTS has a perfect shift length that matches a short clutch travel....so, execute fast shift in that car is a breeze. In fact, the Celica's sporty setup makes for a smooth shifting when you're going extreme and gets hefty/notchy when you're cruising. So, there's trade-offs, but not as much as some other cars (e.g. RSX-S). Anyways, if you're going to get a short shift kit for the Yaris, but keep the the clutch travel the same, it's probably going to make for some awkward shifts when doing things quickly. They've got to match-up...unless, your left foot is faster then your right hand, but I've found that the shift-hand is usually the faster.
Pars is offline   Reply With Quote
Remote Starter with a Manual Transmission SR5-2006 2nd Generation (2005+) 17 12-23-2007 04:45 PM
Manual transmission rough shifting jbaib 1st Generation (1995.5–2004) 7 04-23-2007 09:16 PM
Gen 6 with manual transmission touringcamry 5th & 6th Generation (2002-2006 & 2007-2011) 4 12-22-2006 11:17 PM
Oil in Manual transmission question IvanHoe Camry & Solara Lounge 8 11-17-2006 10:04 AM
MR2 S/C manual transmission question heritage36 MR2 Forum 6 12-29-2005 08:43 AM
