Originally Posted by JeffP
The head lights (the glass covers) are dingy and need to be cleaned; the problem appears on the inside of the glass. I do not have an Echo manual; how do you get the head lamps off without tearing things up? Thanks.
I recently replaced the headlamps on my '04 Echo because of similar problems. I tried the buffer/renew stuff that polishes the lamps on the outside, which worked for a couple months but then got worse...which is what EVERYONE told me would happen (but hey, it was a $10 attempt). But that does nothing for the inside of the lens I know. The problem is that on many Lexan headlamp assemblies the actually laminate them and it's that lamination that actually oxidizes/UV degrades/roughs up and there is nothing you can do about it. I talked with a local auto-detailer who explained it to me and said he could put a new lamination on the outside but is labour intensive and the inside of the lens is a hornets nest because of the silicon glue used is so strong that you'll break the plastic in the process getting it off.
All that said, I purchased 2 brand new lenses for $120 total from Amazon and installed them inside of 1 hour. I didn't take the bumper completely off but did remove all the fasteners and tilted the bumper up to reveal the bolts on the side of the lens. I'd recommend this route as the renewing of old plastic is futile.
