Break lights and cluster question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2007, 10:31 PM   #1 (permalink)
View olegmalkin's Photo Gallery
I recently bought an 01 Echo 5 speed. The dashbard light does not work and neither does the back lights (and break lights). I can live without seeing the dashboard at nite, but I can get pulled over for not having rear lights. I took it to a mechanic yesterday and he said that the problem is in the cluster and if I replaced it, all the lights would work again. That doesn't sound right to me. Anyone an electric guru out there? I would really appreciate your advise.
olegmalkin is offline   Reply With Quote
Old 06-28-2007, 12:29 AM   #2 (permalink)
View toyomoho's Photo Gallery
Why does the mechanic state the cluster is is the problem. Did they mean the light switch?
Do any of the other running lights work, if so the problem may be is in the wiring? Have you checked the fuses, Stop, Gauge, Tail and light bulbs?
The Stoplight switch on the brake system (look at where the pedal connects to frame under the dash) controls on/off operation.
Old 06-28-2007, 07:11 AM   #3 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
I'd get a second opinion on that one. Brake lights are usually unrelated to the cluster...
Old 06-29-2007, 08:49 AM   #4 (permalink)
Ok, my mistake, the brake lights are working. So basically, all the lights (headlights, brake lights, blinkers) are working except for the tail lights and the dashboard light. Other than that dashboard seems to work fine (tempreture, airbag, etc.) Do you think that replacing the cluster CAN solve this problem? Again, my main concern is the tail lights. Anyone has a picture of how the fuses should be set up? Thank you.
92 SR5 gauge cluster and map lights rogerman 89-95 Toyota Pickup/Hilux 1 06-09-2006 04:49 AM
01 Corolla nstrument cluster lights Dadof2 Archived Corolla threads 1 01-04-2006 10:53 PM
lights in the cluster eyz closd MR2 Forum 2 06-30-2005 11:53 PM
Gen. 2 V6 gauge cluster question xavior66 Camry & Solara Lounge 10 08-09-2003 05:38 PM
GEN5 instrument cluster question mach_y 5th & 6th Generation (2002-2006 & 2007-2011) 17 08-18-2002 10:23 AM
