Anyone installed tachometer on 2004 ECHO Hatchback? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2004, 07:43 AM   #16 (permalink)
aspire's Avatar
View aspire's Photo Gallery
Hot wiring the RPM signal
Hi guys! May be this can help you all guys finding and hot wire your correct RPM signal based on model, engine type, and your ECU location but it's in Japanese...
http://www.blitz.co.jp/new-product/R-FIT/R-FIT_TOYOTA.pdf
http://www.blitz.co.jp/Operation-manual/electonic/powermeter-ecu.pdf
Good luck... hope you all find this much useful.
aspire is offline   Reply With Quote
Old 11-13-2007, 08:53 PM   #17 (permalink)
View echo987's Photo Gallery
USA
http://www.geocities.com/psx_play500...ifications.pdf
Check out this site for the wiring diagram, tachometer is labled, On the american modles the OBDII port is a 16 pin the first pin on the bottom row, counting left to right is for the tach. This is for the 2000 Echo.
this wiring diagram can show you the tachometer wire off the computer if you want to go there
echo987 is offline   Reply With Quote
