Right Finally After A Year A Topic About Fixing My Flat Spot, Any Input Appriciated, - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2007, 04:37 PM   #1 (permalink)
Sphinktar's Avatar
View Sphinktar's Photo Gallery
Right Guna try bullet point this as theres lots of info to fit in and i dont wanna bore you with a massive amount of text
if you read on you will understand why i am scared to put a new cat converter in before my MOT as i worry it will happen again
1.3 2000 X reg sr
the problems started when i had a garage take my centre pipe out of the standard exhaust system
was fine at first but then a 2 or 3 month later my engine management light came on
my car then developed a small flat spot which has got worse over time
then it failed its MOT test on emissions he said they were thru the roof
trying too fix the problem i had the cat taken out and looked at, it was totally melted and useless it got binned as the exhaust centre said it had been over fueled
ive since replaced the whole exhaust system with a powerflow system and is currently decat'd
the flat stop has never changed no matter what has been changed on the car
the flat spot is only when first touching the accelerator and the car feels very sluggish untill in high revs
the only way to pull away is to tap the pedal till the revs build up
now for my MOT i have to put a cat back in and am looking to put an envy sports cat in but i dont want to put this in untill the problem is fixed
as if it breaks the cat again im £300 out of pocket
i heard of a simalar problem on an avensis where the first lambda sensor had broke meaning the ECU wasnt gettin the required information
wondered if this could have happened due to the centre pipe being removed and cause the engine to overfuel and ruin the cat?
any input is much appriciated cause i really wanna get rid of this once and for all
had the lamdors out the other day but was no good as you cant tell if there broke from looking at them there just pretty black
if it is overfueling how much am i looking at for toyota to put it right?
if theres anymore info needed jst ask ill get it edited ASAP
thanks in advance alex
Sphinktar is offline   Reply With Quote
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
NAIAS: IS-Fugly trxr Toyota News 33 01-10-2007 09:10 AM
Toyota Announces Best Sales Year In Its 46-Year History, Breaks Sales Record For Eigh CDNVITZ General Discussion 2 02-11-2004 10:22 AM
