What is the redline? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-17-2007, 05:21 PM   #1 (permalink)
JNEG
JNEG's Avatar
Gameroom cash: $284100
View JNEG's Photo Gallery
I'm installing a tachometer which has a movable redline to indicate where you should not go, and I would like to know if anyone knows where the redline
should be for a 2000 ECHO? Thanks.
JNEG is offline   Reply With Quote
Old 11-17-2007, 06:26 PM   #2 (permalink)
View rayrayII's Photo Gallery
if i was you i would not take the echo much higher than 4,000 to 4,500 rpms. its just risking it if you are going much higher. The echo was not meant to be a sports car.For instance, if you had something like a 350Z or hyndai tiburon V6 you could take the rpms up to 6,000 to 6,500 safely since the cars are geared more towards power and racing. However, I have taken mine to about 4,300 rpms with no issues in the first three gears.
rayrayII is offline   Reply With Quote
Old 11-17-2007, 06:33 PM   #3 (permalink)
i forgot to say that taking your car up to 4,000 rpms wont kill your car unless you do it day after day and dog the shit out of it. if you just do it every once and a while your car will be fine.
Old 11-17-2007, 06:35 PM   #4 (permalink)
View monsterzero's Photo Gallery
When I floor it and it down shifts mine usually goes up to about 6000
monsterzero is offline   Reply With Quote
Old 11-17-2007, 07:30 PM   #5 (permalink)
View camryvibe's Photo Gallery
Specification for the 2000 Echo was for maximum HP (108) at 6000 rpm. Redline is normally at least a few hundred rpm above peak HP so is probably at 6500 rpm. But unless you get a definite answer I'd set it around 6200 rpm to be on the safe side.
camryvibe is offline   Reply With Quote
Old 11-17-2007, 08:08 PM   #6 (permalink)
Newbie One Kanobi
ECHOKnight2000's Avatar
Gameroom cash: $664359
View ECHOKnight2000's Photo Gallery
^^^I was going to say yeah the ECHO's I believe for the 1.5ltr is 6,200rpms from my knowledge. I know its not 6,500rpms
Live faster than the speed of fear
ECHOKnight2000 is offline   Reply With Quote
Old 11-18-2007, 07:34 PM   #7 (permalink)
JNEG
JNEG's Avatar
Thanks for the replies
Thanks for all of your replies about the redline. I ended up setting it at about 6,200. BTW, the install went pretty well (Summit-silver G2886, $42.95), will try to get hookup for the ecu so that the wire does not not just stick out- otherwise I'm happy to just see the revs!
Old 11-19-2007, 01:09 AM   #8 (permalink)
View leasaunce's Photo Gallery
drive hard all you want, but just remember to change the oil more frequently.
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Redline MT-90 or 75w-90 in a 5 spd? brohloff 1st Generation (1995.5–2004) 3 08-24-2007 08:21 AM
Redline MT-90 or 75w-90 in a 5 spd? brohloff 2nd Generation (2005+) 1 08-24-2007 12:25 AM
Redline? Syndacate Tercel, Paseo, Starlet, and Sera Forum 12 07-27-2007 08:31 AM
Redline Hood struts, GROUP BUY #2 Yoda-master 2nd Generation (2005+) 412 04-29-2007 07:27 PM
