2003 Echo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-23-2007, 06:12 AM   #1 (permalink)
View agubbin's Photo Gallery
2003 Echo
Hi i am about to service a friends 2003 Echo for the first time. Can anyone tell me anything i may need to know before i start. I am changing oil filter and doing fluid top ups. i did see something about about an oil light needing resetting on one forum. is this right or can i just drop the oil and change the filter change the plugs and top up the fluids. without encountering any probs.
regards
agubbin is offline   Reply With Quote
Old 12-02-2007, 09:18 PM   #2 (permalink)
View echo987's Photo Gallery
Echo just takes what is recommended, It is easy to work on. Antifreeze should be some pink color stuff that is supposed to be good for 15 years or something like that, top off if needed.
echo987 is offline   Reply With Quote
Old 12-07-2007, 02:15 PM   #3 (permalink)
View emaretoo!'s Photo Gallery
pretty much the usual stuff
this first result gives you a good step by step on the basic oil change. echo oil filter change The echo is fairly easy to do basic maintenance on. Good luck!
emaretoo! is offline   Reply With Quote
Old 12-11-2007, 08:36 PM   #4 (permalink)
rwd_3tc
View rwd_3tc's Photo Gallery
Canada
yes the coolant is pink. and no the coolant wont last 15 years. more like only 40000km's.
1981 Toyota Corolla TE71
1990 Toyota Previa
rwd_3tc is offline   Reply With Quote
2003 Echo paint lifting / bad primer? trappem Yaris, Vitz and Echo Forum 3 11-24-2007 08:11 PM
MPG on 2000- 2003 echo, PLEASE HELP ! ckeneman Yaris, Vitz and Echo Forum 5 05-26-2005 12:37 PM
What's this plastic part that came with my 2003 Echo stevefrench Yaris, Vitz and Echo Forum 1 01-26-2005 12:01 PM
2002 Corolla tape deck in 2003 Echo louise Audio, Video, and Security - Tech 1 08-04-2004 11:07 PM
Which transmission cooler hose of 2003 Echo is outlet? sifan Yaris, Vitz and Echo Forum 0 07-29-2004 07:37 PM
