Some Tech questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2007, 04:41 PM   #1 (permalink)
Silver Bullet
SLPR1987's Avatar
View SLPR1987's Photo Gallery
Question Some Tech questions
I've got three questions for everyone out there:
1.) Will and exhaust system for the NPC13 Chassis Vitz RS 5dr fit my NCP12 Chassis 2000 Echo 4dr? I asking specifically about the Fujitsubo Power Getter System ( http://translate.google.com/translat...n%26safe%3Doff )and it looks like it would fit, I emphasize LOOKS. Anyone got an idea??
2.) I've got some slack on my throttle cable and was wondering how to tighten it up a bit without having to buy a bigger rotor. The pedal has about an inch or so of give before engaging the rotor.
3.) I always wondered about the little clipped on cover in front of my HUD (its oval shaped and centered in front of the speedometer). I was browsing for information on my first question and came across this pic http://www.c-one.co.jp/zoom07_image/91vitzrs_bonnet.jpg You should see what I'm wondering about in the center-left of the photo. Anyone know what it is??
2000 'Alpine Silver' ECHO 4-dr; US Gen 1
--Weapon-R Dragon Intake System--DC Sports Header
--KYB GR-2 Shocks and Struts--Tein H-Tech Springs
--TRD by Hotchkis Strut Tie Bar--GReddy Rear Lower Arm Bar
SLPR1987 is offline   Reply With Quote
Old 12-14-2007, 06:40 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
that cover in front of and below the gauges on the hatches had the buttons for gauge cluster brightness and the trip meter.
Old 12-15-2007, 12:53 AM   #3 (permalink)
Silver Bullet
SLPR1987's Avatar
Cool, thanks. One down, two to go!
Old 12-15-2007, 12:51 PM   #4 (permalink)
bgrieger's Avatar
adjust the cable shorter. Either ratchet down the adjuster, or make a new stop for the rotor...2 down.
hatches have no real distance from the rear wheels to the rear of the car. Sedan models have a foot or 2. Given everything else is the same, it likely won't fit as it will come up short. That said, I've never tried to compare. If you got it, you might have a section welded in to extend it as I believe they follow the same path, but you might find other differences. Again, I never bothered to look into it.
Old 12-28-2007, 10:37 PM   #5 (permalink)
Silver Bullet
SLPR1987's Avatar
New question
i got a camber kit for my rear suspension but that was all i could find. Does anyone know how similar the front would be to say an xA? i assume it be almost identical or at least close enought to use a front camber kit meant for an xa right?
Rim questions (not the regular nu b ?'s) urbandork Archived Corolla threads 16 03-20-2007 12:52 PM
Minor questions about the 97 corolla. Driver Archived Corolla threads 6 07-31-2006 10:14 AM
yota tech forums suck balls.... subliminaltrips 89-95 Toyota Pickup/Hilux 28 06-12-2006 04:19 PM
Questions Jayleav 1st Generation (2003-2008) 11 06-04-2006 12:38 PM
Weather Tech Group Buy Goatkey 2nd Generation (2005+) 20 03-12-2006 04:29 AM
