Tyre pressure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2008, 05:39 AM   #1 (permalink)
Reaper316's Avatar
View Reaper316's Photo Gallery
UK Tyre pressure
Hi
I'm about to change the wheels on my '04 1.0L T3 Yaris.
The new wheels are 15" alloys with 195/50/r15 82V tyres.
I was wondering if anyone has any ideas on what tyres pressures i should be using.
On my current standard 14" wheels its 33psi in front and 30 psi in the back.
Thanks in advance for any help you can give.
Reaper316 is offline   Reply With Quote
Old 01-07-2008, 06:29 AM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $398685
View RningOnFumes's Photo Gallery
Whenever I switch to aftermarket wheels that aren't the same as oem, I use the psi rating on the tire's side wall.Right now on my yaris stock 15"s I'm at about 45psi for best mileage reasons.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 01-07-2008, 06:34 AM   #3 (permalink)
Reaper316's Avatar
Cool i'll try that.
Cheers for the help.
Old 01-07-2008, 06:35 AM   #4 (permalink)
Ninja-rator
No problem, stay a while won't you?
Old 01-07-2008, 07:26 AM   #5 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
I usually end up somewhere in between. The tire sidewall pressure is the rated maximum, and is the ideal pressure for carrying the maximum weight load the tire is capable of. It will provide the highest safe gas mileage as well as the tire will be the most ballooned at this pressure it is safe to be. The manufacturer sticker is for the pressure that will hold the car up properly and compromises to gain ride comfort and better traction in exchange for maximum carrying capacity and fuel mileage.
Old 01-12-2008, 04:56 AM   #6 (permalink)
Reaper316's Avatar
Hey cheers for the info guys.
I called a tyre fitters yesterday and they recomended 30psi in the front and rear for 195/50/r15 wheels and to pump them up to 32psi for long jourenys.
Old 01-17-2008, 05:06 PM   #7 (permalink)
View yi5hedr3's Photo Gallery
Yep - generally stick with the pressures on door jam/owners manual if you want soft, comfortable ride. For maximum fuel savings, go to sidewall max (cold). Higher pressures do give better mileage, but less traction.
yi5hedr3 is offline   Reply With Quote
Old 01-25-2008, 12:15 PM   #8 (permalink)
View fidgell's Photo Gallery
Off topic a little but anyone know the wheel nut/lug head size? is it 19mm???
fidgell is offline   Reply With Quote
Old 01-25-2008, 08:14 PM   #9 (permalink)
Don't know about yours, but in '08 I believe they are 21mm.
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
