Originally Posted by thebarber
you should be able to adjust the idle, shouldnt you?
as for the clicking, its likely normal....does your car have an aftermarket intake on it by chance...?
To be honest Im not that knowledgeable about cars, I'm not so sure about the idling problem being adjusted (even though when I first got the car it was fine).
As far as an aftermarket intake...im not sure what you mean by that but as I mentioned...I am 100% sure it's coming from the throttle position sensor (just to clarify in case im wrong...this is a blue plug-like mechanism coming out of the side of the black plastic cover where you find the air filter etc etc). I know its coming from this because whenever I unplug it the clicking stops.
