Never mind. I figured it out. Seems that the 30+ people who read my post either (a) didn't know the answer either, or (b) figured I was too stupid to live so why bother answering the question.
Anyway, for those that read my question but didn't know the answer either, you pop out that little oval access thing at the front of the IP with a small screwdriver and that opening then becomes a handhold so with one good yank toward you, out pops the IP cover. Two Philllips screws hold the IP in place. Pull it straight out (no need to disconnect the two electrical connectors on the bottom of the IP) and then turn it 180 degrees and there are your light bulbs. There is no speedo cable. The bulbs are in little candleabra-like things and there is a colored sleeve that slides over the two "main" bulbs. I had to get the replacement bulbs from Toyota Parts...local auto store didn't have them. Screw the IP back in, push the cover thing back into place until it snaps, you're done.
I replaced both since the IP was out of the dash anyway.
Total R/R time: about 10 minutes.
Total cost: $8
So there you go.
