2000 Echo needs a Tranny Drain and fill? iNSTRUCTIONS? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2008, 11:03 AM   #1 (permalink)
gruvee87vertgt's Avatar
View gruvee87vertgt's Photo Gallery
How many quarts do I need? do I need to remove the trans pan to flush the fluid or is there a drain plug??? thanx
2001 Svt L, 2000 Toy Solara, 2000 Toy echo
Wont you be my friend?
http://profile.myspace.com/index.cfm...e-34a8a4b64cdf
gruvee87vertgt is offline   Reply With Quote
Old 05-23-2008, 02:02 PM   #2 (permalink)
View n00b's Photo Gallery
Automatic:
If you want to do a simple drain - refill, all you'll need is a 10mm hex socket, a funnel, and about 3 quarts of the correct ATF fluid. If you want to take out the pan, you'll need a 10mm socket and a gasket. New ATF fluid is added through the dipstick tube with the funnel.
n00b is offline   Reply With Quote
