5e-fe question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2003, 07:33 PM   #1 (permalink)
CanadaGTS's Avatar
View CanadaGTS's Photo Gallery
5e-fe question
i have a 92 paseo, what the idle suppose to be at when the engine is at the normal running temp. In drive it around 600 to 700 and in park it at 800, is this normal for this engine cuz it feels like it gonna cut off. i did an injector clean out, at canadian tire, full complete tune up (plugs, wires, cap, belts etc.) can't think of anything else. Also can u adjust the idle on this engine? or can it be something else that i over looked.
CanadaGTS is offline   Reply With Quote
Old 11-15-2003, 01:25 AM   #2 (permalink)
Corsa!
Galvatron's Avatar
View Galvatron's Photo Gallery
These are normal speeds
1992 Tercel DX, 3E-E/3AT
1992 Paseo, 5E-FE/5MT
2007 Suzuki SV650S
http://www.rent-a-tech.org/wordpress
Galvatron is offline   Reply With Quote
Old 11-27-2003, 11:03 AM   #3 (permalink)
View Nico's Photo Gallery
If it's a 5sfe engine, might be a vaccuum problem. Check all vaccuum hoses, egr valve and egr vaccuum modulator (there's a kind of filter inside of it that you can clean up). Apart from you have checked 'till now and this I would probably start thinking of checking compressions on all cylinders...
Nico
Nico is offline   Reply With Quote
Old 12-01-2003, 05:30 PM   #4 (permalink)
CanadaGTS's Avatar
thanks for the info, but it wasn't that it was all replaced before i got teh car new house cleaned out egr valve, it was stupid petro canada crappy gas that was causing it. i when to esso a week later and in was fine.
