Since the yaris is so similar to the echo, let's see if these proven methods will apply to you.
1. DFCO.. Deceleration Fuel Cut Off. In 08 model Yarii it's all gears, in 07s, it started with 3rd and lower. It's basically engine braking but with no fuel. Since the Echo might still have it at 3rd gear or less. Try to coast more when you are at speed comprarable to 3rd gear or less. This means coasting up to lights, stops, etc.
If this works... you should see Instant MPG go to 999999.
2. In your multi guage mode, use TPS.. drive with it at 21 TPS. You'll notice that this is the golden number as instant mpgs will shoot up.
3. Use the RPM gauge if you don't have a Tach. Try to stay under 2500 rpms.
4. Newly discovered for the Yaris: "Hangtime"
Attain cruising speed. Now slightly pull off the accelerator. Notice that you aren't slowing down but your instant MPGs just shot up to 100 + mpgs. Hangtime is believed to be associated with the vvt-i system
So try all these if you want to get technical.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
