01 Echo bogs down at WOT - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2008, 06:02 PM   #1 (permalink)
View echo01's Photo Gallery
Canada 01 Echo bogs down at WOT
I don't have the money or resources until payday to check the engine codes.
however I was wondering if anyone has had this problem in the past that could help.
When driving through the gears (5 spd manual) the engine revs fine until I press the gas past 3/4 pedal, then it just bogs instantly until I let off the gas a little.
My car will idle perfect, and the clutch is fairly new.
Anyone have an idea?
Thanks for your time.
echo01 is offline   Reply With Quote
Old 06-07-2008, 08:02 AM   #2 (permalink)
Thumbs up fixed
I did some searching and found that after cleaning the MAF sensor, the car runs like new again!
I love a cheap fix!
The sensor probe in the MAF was caked with a black layer...soaked a Qtip in rubbing alcohol and carefully cleaned it off and dried it.
After reseting the computer by disconnecting the battery...runs like a charm!
Thanks for your time!
Old 06-07-2008, 08:28 AM   #3 (permalink)
not4sale's Avatar
View not4sale's Photo Gallery
Could be a fuel filter? But have your code(s) checked before you spend money trying to guess what the problem might be. If you have the tools and feel like it, you might want to try looking at the MAF meter to see if it's dirty. There should be one exposed wire, maybe a couple more wires that may be hidden...not too sure about the layout. If they're dirty looking, clean with q-tip and alcohol, or CRC MAF meter cleaner...a scanner will check the flow of the MAF at wot...calculated engine load should go over 80% at wot. Last one I came across would only hit 61% at wot. It didn't have much top-end power until I cleaned the MAF meter.
2008 Toyota Yaris 3-door
Scotchgard™ Paint Protection Film, Wolf's Head SD 5w30, Casite oil filter
not4sale is offline   Reply With Quote
Old 06-07-2008, 08:34 AM   #4 (permalink)
not4sale's Avatar
Sweet. I took too long sending a reply, it appears.
btw, if you noticed one big wire with a brownish tip, there might be 2 more hidden up high in the sensor. If so, they'll more than likely be dirtier than the exposed wire.
Glad you're back in business.
Old 06-07-2008, 09:14 AM   #5 (permalink)
Yeah I noticed those wires inside and cleaned them too.
Thanks for your help.
