swap probs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-04-2003, 03:20 AM   #1 (permalink)
View slay's Photo Gallery
swap probs
hey everybody.. new to the forum
i just swapped a 5efhe (its from japan so im guessing its the H motor) with 40 000k on it in to my 91 tercel
we used the 3ee ecu with the 3e fuel rail and injectors.. also added a new cold air intake
the problem is it runs alittle on the rich side.. actually alot.. 174 KM on a half tank of gas
any suggestions on what this could be? sometihng ecu related im guessing.. co2 sensor maybe.. i really dont know
slay is offline   Reply With Quote
Old 12-04-2003, 10:09 PM   #2 (permalink)
Corsa!
Galvatron's Avatar
View Galvatron's Photo Gallery
Re: swap probs
I'm pretty sure you need the 5E-FHE ECU
1992 Tercel DX, 3E-E/3AT
1992 Paseo, 5E-FE/5MT
2007 Suzuki SV650S
http://www.rent-a-tech.org/wordpress
Galvatron is offline   Reply With Quote
Old 12-04-2003, 11:18 PM   #3 (permalink)
Tercel Power
View arknoid's Photo Gallery
yeah ditto on what galv said, but hey man i wanna see ur car since this is a swap i was considering.
93 Tercel/88 Jetta
arknoid is offline   Reply With Quote
Old 12-04-2003, 11:54 PM   #4 (permalink)
the 5efHe ecu wouldnt run.. the sensors are all different.. the mech said it wouldnt even run with it
what i did was adjust my timing ALOT.. the car is really sluggish but it seems to be abit better on fuel
arknoid.. were are you exactly? i work down on norfinch... my car doesent look good but the motor is good
Old 12-30-2003, 12:50 AM   #5 (permalink)
View AreSTG's Photo Gallery
5efhe ecu will work with a custom wiring harness
AreSTG is offline   Reply With Quote
Old 01-25-2004, 12:03 PM   #6 (permalink)
View GT_REVVA's Photo Gallery
Well, you don't really need the 5EFHE ECU to make the motor run. You need it to get all 110 horses though. If you're running it with any other ECU apart from the FHE unit, you'll need to run everything from your original motor i.e. if you're using a 3EE ECU to operate then, you'd need the 3EE injectors, throttle body and, a 5EFE distributor modded with one of the 3E plugs and, you're good to go. Same thing if you had a 5EFE before and intend on going FHE. If you're using aftermarket headers (like Pacesetters)make sure that when you install your 02 sensor, it protrudes into the exhaust stream. If it doesn't, then the ECU won't get a reading and, the car'll run rich. Do NOT try to use the 5EFHE injectors if you do not have the ECU to go with it.
GT_REVVA is offline   Reply With Quote
