SRS Warning Light, and Horn not working
2001 ECHO
SRS warning light came on recently, and I thought it to be unrelated to the horn not working at about the same time. But as I found after some testing and wire tracing, they both use the same rotating contacts directly under the steering wheel. I unpluged both the horn wires and airbag wires and none of them had continuity through this device. So I must conclude that it is defective, Right? So my Question is what is name of this set of contacts and how do I reset the SRS light after I replace the defective part?
No codes were set in OBD II, I think the SRS is a stand alone system and will not set codes in OBD II anyone know if this is correct?
