Tire Size-195/60R14 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2008, 02:46 PM   #1 (permalink)
Tom, 2000 Echo, manual
View slowlane's Photo Gallery
USA Tire Size-195/60R14
Hi All, Anybody tried putting 195/60R14 tires on to replace the OEM 175/65R14s? The 195 is taller by .8 inches in circumference and .2 inches in diameter according to the tire size calculator on Miata.net.
I have a 2000 Echo.
slowlane is offline   Reply With Quote
Old 10-25-2008, 08:59 AM   #2 (permalink)
View Dake's Photo Gallery
They should fit fine. I've got 185/60/R14 on the front and 195/70/R14 on the back of my '01 Echo. I had to take the mudflaps off the back b/c the bigger tires just barely rubbed, but if you stick with the same general sidewall height, you should be fine. I do have a set of old Tercel Firehawk rims though, but I wouldn't think they're much different than stocks except in appearance.
I used to have the 195/70s all the way around but they took away about 4 mpg, so I switched the front out to the slightly smaller size and gained it back (probably a combination of smaller diameter and lowering drag and rolling resistance).
Dake is offline   Reply With Quote
Old 10-25-2008, 09:59 PM   #3 (permalink)
Thanks Dake. With the 195's there are a lot more (and better) tire choices, plus I would'nt mind having the extra tire width.
