ecu - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2003, 03:19 PM   #1 (permalink)
View 91jdm_t3e-e's Photo Gallery
ecu
does anybody know of an ecu swap or upgrade for the 3e-e motor? i heard of someone talking about a 5efe ecu but i dont think it would work cuz 3e-e=SOHC 5efe=DOHC
91jdm_t3e-e is offline   Reply With Quote
Old 12-20-2003, 03:59 PM   #2 (permalink)
View Deep's Photo Gallery
True DOHC and SOHC ecu's aren't interchangable, if the 5E uses a scissor gear then its possible. But I don't know too much about the E series motors, so you'll want a second opinion.
Deep is offline   Reply With Quote
Old 12-21-2003, 12:13 PM   #3 (permalink)
My Dixie Wrecked
wedge's Avatar
View wedge's Photo Gallery
Yeah, the 5E is a DOHC, but both cams are turned by the same gear. So it works in a similar way to a SOHC but has the better flow of a DOHC.
In any case, whether a 5E ecu will work on a 3E or not (I don't have that answer btw), it won't give you much, if any, performance increase at all. All E series motors are tuned for fuel economy and reliability. The only way to get a good increase from an ecu upgrade is to get it reprogrammed, or use a stand-alone ecu. But those should be considered last resorts. There are many other upgrades that can be done, for significantly lower cost.
Racing is everything
wedge is offline   Reply With Quote
