Transmission clunks when shifted to reverse
Hello everyone.
I have problem with transmission making a clunking noise.
Car:
2009 Yaris 5-door liftback with automatic transmission.
ABS is standard.
It has only 450 miles on it.
Problem:
When the gear is shifted to reverse, it makes a clunk noise once.
When it happens:
Happens only after I drive 8 miles or more and shift the gear into reverse.
Happens even if I put the gear to neutral and wait a few secs before putting it to reverse.
Happens even if I put the gear to park and wait a few secs before putting it to reverse.
When it does NOT happen:
When the car is just started.
When I drive only 5 miles or less.
Once it makes a clunk noise, it won't make the noise again until I drive another 8+ miles.
If I drive over 30 miles without shiting to reverse, then it doesn't make noise.
So far, when I drive 8-15 miles, it made clunk noise 100% of the time.
When I drive 5 or less miles, it didn't make clunk noise even once.
I drove over 30 miles twice and it didn't make noise those two times.
The loudness of the noise is not consistent.
Sometimes, it's only a loud click. But sometimes it's loud enough of clunk that anyone would notice.
I wanted to see if anyone knows what this noise is.
I'm not wanting to taking the car to the dealer because it only can be recreated after driving 8 miles or more.
I'm thinking they would test it without driving that far and finds everything is ok.
Any help will be appreciated.
Thanks in advance.
