The boot should either shimmy off or just come off with the plug,you wont damage the boot as its made of tough stuff,when i put it back on i usually wipe a dab of silicon lubricant around the inside so it comes off easier the next time you do it.When changing bulbs be careful not to touch any part of the glass on the new bulb as the glass has to remain scrupulously clean or it will prematurely burn out.
PS check your owners manual i think it tells you the process somewhere in there.
