2000 Echo......will not idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2008, 06:15 PM   #1 (permalink)
View montel's Photo Gallery
Canada 2000 Echo......will not idle
I hae a 2000 echo. A week ago the check engine light came on. At the same time, when i started the car when it was cold, it will not idle....it will just stall. If I keep giving the car gas, or drive away it works fine. When the car is warm it idles fine.
Any suggestions as to what is happening?
Thanks in advance.
montel is offline   Reply With Quote
Old 12-10-2008, 01:15 PM   #2 (permalink)
thebarber's Avatar
View thebarber's Photo Gallery
check the CEL
could be lots of things...
thebarber is offline   Reply With Quote
Old 12-17-2008, 04:27 PM   #3 (permalink)
View bmansully77's Photo Gallery
My wife's 2001 echo did that except the check engine light didn't come on. I had to replace the idle air control valve, the idle air control valve gasket, and throttle body gasket. Parts cost me $243 (American) and additional $90 labor.
bmansully77 is offline   Reply With Quote
Old 04-30-2009, 03:21 PM   #4 (permalink)
BobProd
View rfice's Photo Gallery
I had the same problem several years ago. A code check will verify if it is the Idle Control valve.
code P0505 CHECK ENGINE light.
In Canada is was a bit (lot) more expensive.
Good luck.
rfice is offline   Reply With Quote
Old 05-02-2009, 08:15 AM   #5 (permalink)
View 05DCLB's Photo Gallery
Many times the valve can be cleaned with carb spray.
05DCLB is offline   Reply With Quote
