Where do I post this? 2000 Toyota Echo is hesitating.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2008, 07:09 PM   #1 (permalink)
gruvee87vertgt's Avatar
View gruvee87vertgt's Photo Gallery
Question 2000 Toyota Echo is hesitating....
swapped the plugs last night.....still hesitating....
it does it sparadically......regardless of warm or cold.
it does it when it's in park and stopped when in drive...not when accelerating...
talk to me people!
2001 Svt L, 2000 Toy Solara, 2000 Toy echo
Wont you be my friend?
http://profile.myspace.com/index.cfm...e-34a8a4b64cdf
gruvee87vertgt is offline   Reply With Quote
Old 12-12-2008, 03:51 PM   #2 (permalink)
bingo....bad coil...still NOT IDELING RIGHT THOU!
Old 12-13-2008, 01:35 AM   #3 (permalink)
jambo101's Avatar
View jambo101's Photo Gallery
Try replacing the wires leading to the plugs.
jambo101 is offline   Reply With Quote
Old 12-13-2008, 01:44 AM   #4 (permalink)
just a nobody
It has four individual coils!
N.E.O.
Old 12-13-2008, 01:48 AM   #5 (permalink)
just a nobody
Can you elaborate further on that? How is it still not idling right? Idle rough or ?
What does 'it does it when it's in park and stopped when in drive...not when accelerating...' mean?
If it is the coil, it should have set an engine misfire code, do you have a CEL?
Hesitation could have been cause by a lean fuel system, dirty MAF or restricted injectors maybe?
N.E.O.
Old 12-14-2008, 10:35 PM   #6 (permalink)
View drshawn's Photo Gallery
I am having the same problem with my 2000 Toyota Echo. My check engine light is on. Last year the mechanic did his check and had me by an O2 Sensor. The check engine light still came on.
This weekend i went to Auto Zone and bought some MAF cleaner. I was told to spray the cleaner on the thin wires inside the hole. So I sprayed it several times. The instructions told me the check engine light should go off at the next system check....
My question are the thin wires in the hole the sensor or is that part that you pull off the sensor? Should I spray the part that I pull off?
Does that make sense?
Thanks
Shawn
drshawn is offline   Reply With Quote
Old 12-15-2008, 12:37 AM   #7 (permalink)
just a nobody
Instead of just cleaning the MAF sensor, you might want to find out what your current code(s) is. There are other circuits that can cause the CEL to come on, and MAF circuit is but one of them.
For your questions about the MAF, you have to remove the MAF sensor by taking out the two small screws, take care not to lose them. The portion of the sensor that goes into the intake duct is the part that you need to clean. Take care not to get the cleaner on the O-Ring, not good for it. You can disconnect the battery cables, negative first, and touch them together to clear the code; however, you better be sure that it is the same code first. When you connect the battery cables again, the ECM might take a little bit of time to 're-adjust' itself so the engine may not necessary run very good.
Keep us posted.
N.E.O.
Old 12-15-2008, 02:05 AM   #8 (permalink)
jambo101's Avatar
Has this problem been happening for more than your current tank of gas? You might have nothing more than a bad tank of gas from your last fillup.a couple of bottles of water evaporator/displacement might be the cure.They call it gasline antifreeze up here.
Old 12-19-2008, 04:23 PM   #9 (permalink)
I have had this problem with my check engine light being on for well over 14 months. Last year took in to shop and was told to get o2 sensor...spent close to $200.00 dollars and it didn't work.
Was fixed last year for about 20 miles and then came back on.
After I cleaned the MAF last week, the check engine light went off for 2 days. Came back on. Bummer, I didn't take to get inspected and my inspection is up after this month. I have tried to clean sensor 2 more times since and nothing different.
What is o ring?
Any other ideas? I am getting desparate.
Thanks
Shawn
Old 12-19-2008, 09:38 PM   #10 (permalink)
just a nobody
When you pull the MAF sensor, you didn't see the o-ring used to seal the sensor to the intake duct?
Unless you pull the code, there isn't much we can do, as I had mentioned, we need to know what area it is that the ECM is seeing a problem.
N.E.O.
Old 12-19-2008, 10:50 PM   #11 (permalink)
how do I pull the code? is that running a diagnostic?
Old 12-19-2008, 10:55 PM   #12 (permalink)
just a nobody
No that is just retrieving the code from the ECM's memory. The diagnostic part comes after you know what area of the Engine Control system you are having problem with. Some of the other members mentioned that some of the AutoZone stores will pull codes for you for free, might want to give them a try if you have any AutoZone in your neighborhood.
N.E.O.
Old 12-19-2008, 10:56 PM   #13 (permalink)
I've got an autozone near my house. What do I exactly ask them?
Old 12-19-2008, 11:13 PM   #14 (permalink)
just a nobody
Tell them you have a check engine light, and ask them if they can retrieve the code for you.
N.E.O.
