HELP: warranty and dashboard lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2008, 12:32 PM   #1 (permalink)
View exar_khun's Photo Gallery
I bought a used toyota 2007 yaris CE model last october 2008 from a Suzuki dealer. Just yesterday the lights on my dashboard just went off dead (ie. no lights on the speedometer when i turn on my head lights but lights on engine/abs/clock is working when i do not turn on gthe headlights).
My questions are:
1. Is my understanding correct that since my cars odometer is still less than 40000kms, the car is still under warranty? If so, the manufacturer (toyota) will be able to do both an electrical check and replace the necessary parts (ie. bulbs), if required, FOR FREE since the car is still under warranty, right?
2. if such service in not included in the warranty, how do i replace the bulb or check check the electricals? is it expensive to have someone check and replce the parts for such a problem?
Hope somebody can help me out with my problem.
Thanks in advance!
exar_khun is offline   Reply With Quote
Old 12-14-2008, 12:44 PM   #2 (permalink)
just a nobody
Did you check you dimmer switch? You may have accidentally turn it down, should be somewhere on the dash.
Warranty usually goes with the car, doesn't matter what dealer you purchased the vehicle from as long as it is still within the mileage and time.
N.E.O.
Old 12-14-2008, 12:49 PM   #3 (permalink)
N.E.O.
before yesterday i did not touch/adjust any dimmer switch?
so the warranty includes electrical problems such as the lights dashboards and the like?
Old 12-14-2008, 12:51 PM   #4 (permalink)
just a nobody
Should be bumper to bumper, unless the part had been modified, like aftermarket bulbs. After the regular warranty, there are also the Powertrain and Emission warranty, which are different.
Did you get any owner's manual with the car?
N.E.O.
Old 12-14-2008, 12:55 PM   #5 (permalink)
N.E.O.
yap i have the owenrs' manual. why?
also, would the warranty be affected if i had a car starter installed?
Old 12-14-2008, 01:24 PM   #6 (permalink)
just a nobody
Some of the information would be in the owner's manual.
Car starter? The one that mounts on the engine or are you referring to a remote starter setup?
Usually, unless the problem is directly related to what you had done, it would still be covered under warranty.
N.E.O.
Old 12-14-2008, 01:52 PM   #7 (permalink)
N.E.O.
yeah, i had a remote car starter installed...so this will not affect my warranty right?
Old 12-14-2008, 02:03 PM   #8 (permalink)
just a nobody
What I am saying is that if the problem that you are having is not a result of or cause by what you have installed. For example, you install the remote starter system, and the radio shorted out because of the remote starter system, then there is no warranty on that. However, if you install the system and the suspension makes noise, there is no connection between that what you had done, then warranty should cover that.
You better make sure you didn't leave something unplugged when the remote starter system was installed. Were the lights working before the remote starter system was installed?
N.E.O.
Old 12-14-2008, 02:17 PM   #9 (permalink)
N.E.O.
yap, the lights were working before and after the remote starter was installed...
Old 12-14-2008, 04:04 PM   #10 (permalink)
just a nobody
Not sure how involved it was installing the system, but I would definitely double check that first.
N.E.O.
Old 12-17-2008, 01:58 AM   #11 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $398260
iTrader Score: 13 reviews
sorry, JUST noticed this...moving it to the correct model forum
HaHa
Old 12-17-2008, 04:56 AM   #12 (permalink)
jambo101's Avatar
View jambo101's Photo Gallery
I also had a bad experience with a Suzuki dealer a few years ago here in Montreal. the beautiful 2yr old demo i purchased turned out to have been a restored write off,the car literally fell apart shortly after the warantee expired and ended up being scrapped before it reached 20k kms,the problems started with strange electrical problems.legal action got my money back but i was quite surprised that Canada's largest Suzuki dealer would stoop to selling renovated wrecks to make a buck.
As for remote starters ?i've had a lot of friends who have had electrical problems after a shoddily installed remote starter,seems they tap into the main wiring harness to wire these things and shorts can result or the system may not be compatible with some electronic component.
jambo101 is offline   Reply With Quote
Old 12-17-2008, 01:44 PM   #13 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
and your basic new car warranty is 3 years or 60000kms, whichever comes first
Stevo_Echohb05 is offline   Reply With Quote
Old 12-17-2008, 03:17 PM   #14 (permalink)
jambo101's Avatar
3yrs came first in my case.
