Electrical issue with 2001 Echo
Hi
My father has been having some trouble with his 2001 Echo and since he's being more than apathetic about it, I've decided to take it into my hands to help him fix it.
The issue seems to be electrical. When the driver's side door is opened, the dome lights don't turn on when set to door mode, no chime rings if the headlights are left on when exiting through the driver's side, and the speaker (also in the door) doesn't work.
My father is an electrician and I'm sure the problem is fairly simple to fix, but he's wary of looking inside the door since he's not sure where the problem might be. I'm wondering if there's anywhere I can get a map of the electrical work in there or if anyone can suggest some easy places to get in and test the voltage.
It's not a fuse issue, we've changed all the fuses that could possibly be pertinent to this. And he's not too keen on taking it to the shop when he can drive the car fine anyway.
It's a 4-door 2001 Echo, fyi.
Thanks in advance!
