What sensors are available to be read by and OBDII scanner?
I recently purchased a 2007 Yaris S sedan with a ton of options and a bluetooth OBDII Scanner. With the OBD I don't seem to be picking up a MAF reading, there is only 1 oxygen sensor being displayed (there should be at least 2), the vehicle speed (mph) is sometimes negative (as much as -37), and the intake air flow rate (lb/min) is always 0. I'm not getting any trouble codes, but that just seems weird to me. I was hoping to track mpg using the OBD, but I need MAF readings to do that. I know the scanner works, because it worked on another car I had and everything made sense, except for the intake air flow rate, which was again always 0. I did call a Toyota dealer about the MAF and they said the 2007 Yaris doesn't have one. That doesn't seem right. So, does anyone know why the above would happen and is there a list of sensors one should be able to access with an OBD?
