idle problem 2008 Yaris standard - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2009, 03:29 PM   #1 (permalink)
View zarkov's Photo Gallery
Well I bought this car with the idea that it would be a fairly trouble free ride for a few years anyway. It is what I wanted until I started stalling ocaisionally . It would and does happen once in a while. I will be sitting at a light usually in gear and I would notice a slight rough feel in the engine . I see the tach go down a couple hundred r's too. Then I let the clutch out and if it happens to be at the same time as this weird intermittant burp then it stalls but most of the time the car is fine. I talked to the service at my dealer and they said the Yaris has a touchy clutch and that I will get used to it ummm. Now I have driven vehicles for over 40 years and these cars were made for joe avaerage to get in and drive ,not be careful how you let the clutch out. If I have to slip the clutch well then the $1000 clutch job will happen years before it should.
Thanks for listening , Zarkov
zarkov is offline   Reply With Quote
Old 03-04-2009, 04:41 AM   #2 (permalink)
View DaiFai's Photo Gallery
Is the MIL on?
DaiFai is offline   Reply With Quote
Old 03-04-2009, 05:26 AM   #3 (permalink)
View CJCride's Photo Gallery
Canada Warranty
Try another Dealer.
CJCride is offline   Reply With Quote
Old 03-07-2009, 07:00 AM   #4 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $398685
View RningOnFumes's Photo Gallery
Wait, Wait! Why are you in gear at a stop? I have a feeling I want more info.
You do realize that if you are stopped, in gear and the clutch is depressed-- if you lift on the clutch without giving it some gas you will stall right?? (I suppose since you've driven many cars over the years that you know this.)
I don't think anything is wrong (yet-more info may say so). The yaris is a throttle by wire system, which means it is finicky compared to other cars. It's just something that takes time to get used to.
The main remedy is to give it extra gas until the clutch catches.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
