How to reset 2000 Vitz Computer? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2009, 06:09 PM   #1 (permalink)
View Rory's Photo Gallery
I want to reset the adaptive learning part of the CPU, just changed the O2 sensor and cleaned the MAF. Do I just remove the battery neg and pos cables for a certain amount of time?
Thanks.
Bahamas Real Estate
Rory is offline   Reply With Quote
Old 03-08-2009, 03:29 AM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $398685
View RningOnFumes's Photo Gallery
Yes, you can do that or you can just pull the ECU fuse found under the hood I believe (if not there in the one by your knee).
I would let it sit for a good 10 minuteS?
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 03-08-2009, 07:21 PM   #3 (permalink)
Hi, do you just pull the fuse out with the battery still connected as normal? I tried it with the battery out, maybe I need to do it just with the battery connected as normal.
Also, there are 2 fuses that say ECU: ECU-IG and ECU-B .. guess I need to do both of them?
Thanks.
Bahamas Real Estate
Old 03-08-2009, 09:51 PM   #4 (permalink)
Ninja-rator
How long did you have the battery off? That should have done the trick and you wouldn't have needed to do the ecu fuse.
Old 03-08-2009, 10:17 PM   #5 (permalink)
I had it off for maybe half an hour or so.
One of the trips still had the same millage so dont think it reset.
Anyway im leaving it off overnight right now and will see how it goes.
if that doesnt work then ill try pulling the fuses with the battery connected as normal.
thanks.
Bahamas Real Estate
Old 03-08-2009, 10:35 PM   #6 (permalink)
Ninja-rator
No, the trip meter doesn't reset unless you manually reset it-- has it's own memory and shouldn't be used as a sign that the ECU was reset.
Go ahead and leave it over night but I think you already did the trick. Tomarrow drive as you wish the computer to learn your habits.
Old 03-08-2009, 10:56 PM   #7 (permalink)
ok thanks, will see how it goes.
I also read about touching the battery cables together, at least for a jeep.
the cables on my car wont even reach each other though
Bahamas Real Estate
Old 03-08-2009, 11:32 PM   #8 (permalink)
Ninja-rator
Good Luck.
