engine noise Yaris 99 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2009, 09:25 AM   #1 (permalink)
View lukbeat's Photo Gallery
European Union engine noise Yaris 99
hi, I have Toyota yaris (vitz) 99. I noticed that during acceleration, there is noise from the engine for some time. I investigated it and discover that if I put some lubricant or grease on place witch I marked on picture the noise disappear. Unfortunately after one or two days noise appear again. I suspect that the bearing is gone. Can you advise am I right and if it's possible to change the bearing myself? regards, Lukas
picture link: http://picasaweb.google.pl/lukasz.po...eat=directlink
lukbeat is offline   Reply With Quote
Old 03-13-2009, 01:46 PM   #2 (permalink)
greenpower's Avatar
View greenpower's Photo Gallery
It could be the belt also, if the bearing is faulty the dealer sells the whole pulley, but still a quick repair, you can do it yourself nicely.
RCastro
84' 230E Mercedes
88' GX71 Cressida
greenpower is offline   Reply With Quote
Old 03-13-2009, 01:52 PM   #3 (permalink)
View n00b's Photo Gallery
belt squeal
the only thing you should put on it, if at all, is belt dressing.
make sure the belt is properly tensioned
I've reduced but not eliminated the squeak on my car (1nz-fe) to low rpm moderate throttle by making the belt tighter.
n00b is offline   Reply With Quote
Old 03-13-2009, 02:51 PM   #4 (permalink)
thanks for replay, do you know the place on the web i can buy a whole set on the proper bearing only. Anyway do you know what bearing is it , is it water pump bering ?
Old 03-14-2009, 09:47 AM   #5 (permalink)
greenpower's Avatar
As i see in your pics, the water pump is the bigger pulley at the left of the arrow. The one you're pointing at is just a guiding pulley.
RCastro
84' 230E Mercedes
88' GX71 Cressida
