echo code cheats? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2009, 01:13 PM   #1 (permalink)
View olivertwisto's Photo Gallery
echo code cheats?
Is there a way to check codes on an echo without an OBD II tool? On some older toys you could bridge 2 fuse slots to make the check engine light flash the code, is there a similar trick for the Echo? I'd sure appreciate knowing! FWIW, the car is/was running fine, but this is the 2nd time the light has come on in as many weeks, I think it might be trying to tell me something
olivertwisto is offline   Reply With Quote
Old 03-27-2009, 01:14 PM   #2 (permalink)
duh, should mention that it's a 2001 Echo
Old 03-28-2009, 12:56 AM   #3 (permalink)
View n00b's Photo Gallery
Sorry, you need an OBD II code reader. Make sure your gas cap is tight.
n00b is offline   Reply With Quote
Old 03-28-2009, 07:22 PM   #4 (permalink)
Half a Bubble Off Plumb
Yaris Hilton's Avatar
View Yaris Hilton's Photo Gallery
Smile
I bought an OBD II code reader/resetter a while back when I saw it at the Wal-Mart for a hair under $60. I think I've seen one online for around $45 recently, and I'm sure they'll come down. Still a chunk of change, but if it helps you find and fix a problem without having to put it in the shop, well worth it.
I understand that some of the auto parts shops will do a free code reading for you now.
Yaris Hilton is offline   Reply With Quote
