unknown cable from an echo 2001 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2009, 10:26 PM   #1 (permalink)
View oscarjf's Photo Gallery
i bought a 2001 echo and a little oval shaped cover was missing in front of the instrument panel, inside of it was a cable, can someone tell me what it is?
oscarjf is offline   Reply With Quote
Old 05-04-2009, 09:32 AM   #2 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
It's the trip reset switch from the 2002-08 and up (probably only seen on 2003 - 2005)
Can you reset the trip counter?
Stevo_Echohb05 is offline   Reply With Quote
Old 05-04-2009, 06:40 PM   #3 (permalink)
yeah i can reset the trip counter
Old 05-05-2009, 10:52 AM   #4 (permalink)
Looks like someone replaced the shroud around your cluster with one from a newer car
Old 05-05-2009, 05:19 PM   #5 (permalink)
should i worry about it?, could they have changed the odometer with that thing? also the MIL light turned on today with P0040 code
Old 05-06-2009, 10:55 AM   #6 (permalink)
No, don't worry. If you can reset your trip meter they probably only changed the trim and not the odometer. On the newer models the reset switch goes where that hole is.
Are you sure it;'s not code p0440 for the evap system?
Old 05-06-2009, 06:43 PM   #7 (permalink)
no it was P0040, im going to check the O2 sensor with this guide http://www.carspace.com/guides/Toyot...ytic-O2-Sensor to see if that is the problem
