4E-FTE Upgrades - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2004, 09:25 AM   #1 (permalink)
Turbo Bitch!!!
LBT96's Avatar
View LBT96's Photo Gallery
4E-FTE Upgrades
What should I upgrade after I get the 4E-FTE??
I'm upgrading the fuel pump to a supra pump, and getting a high flow cat...
What else should I upgrade while I'm at it?
** link is in violation of signature rules **
MY EBAY AUCTIONS
LBT96 is offline   Reply With Quote
Old 01-29-2004, 08:44 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Brakes?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 03-01-2004, 11:57 AM   #3 (permalink)
View NDR008's Photo Gallery
rissing rate fuel pressure regulator
2.5" exhaust piping besides a high flow cat (i decated - still passes UK emission standard test).
A boost gauge + actuator for higher boost (dont over do it)
if u boost high enough, you'll need an HKS FCD.
Oh yeah, change the stock blow off valve.
Throw out the crappy stock air filter.
hmmmmmmm.................. those come to mind
You shouldn’t drive for the thrill, but for the pleasure of tasting the control…
NDR008 is offline   Reply With Quote
Old 03-01-2004, 12:06 PM   #4 (permalink)
My Dixie Wrecked
wedge's Avatar
View wedge's Photo Gallery
A good suspension will make the car alot more fun to drive.
Racing is everything
wedge is offline   Reply With Quote
Old 03-01-2004, 06:26 PM   #5 (permalink)
Turbo Bitch!!!
LBT96's Avatar
Appreciate the suggestions.
What I have so far is:
1)Faze Boost, Temp, and air/fuel gauges
2)eiBach Pro Kit springs
What I'm getting soon:
1) KYB-GR2 struts/shocks all the way around
2) d\R Lightweight rims w/hyrdoedge michelen tires (I'm paranoid of rain).
3)Anti-sway bars, front&rear
4)Hood scoop
Much later:
1) Tubo upgrades
MY EBAY AUCTIONS
Old 03-14-2004, 08:22 PM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
LBT, you have rear disk brakes yet? If not are you looking for an axle? Let me know...
雄のハヤブサ
Old 03-14-2004, 09:35 PM   #7 (permalink)
1nzfe addict
View toymaniac's Photo Gallery
after the gr2 and sway bars ....
brakes!!!
a good set of pads metal master or other good brand and good drilled discs....
maybe even replacing the rubber lines to stainless
and do a brake fluid flush put some good stuff in there....
Toymaniac ADM. ClubEchoQuebec.com
toymaniac is offline   Reply With Quote
Old 03-15-2004, 07:36 AM   #8 (permalink)
Turbo Bitch!!!
LBT96's Avatar
Rear disks? No, I don't have them. I've been debating on getting those.
And as far as disks go, I would get Powerslot slotted rotors before I get drilled.
MY EBAY AUCTIONS
Old 03-15-2004, 06:24 PM   #9 (permalink)
N/A bites
Tercel GTS's Avatar
Lemme know if you wanna buy the rear axle. I got a killer deal on mine and I'll pass it on to you if you want. I also had the pads relined so they're thicker than brand new. Why would I part with it already you ask? Just as Trevor did I have to go 5 lug. No sense having two spares so I may as well 5 lug the rear also.
雄のハヤブサ
Old 03-15-2004, 10:01 PM   #10 (permalink)
Turbo Bitch!!!
LBT96's Avatar
I shall keep that in mind GTS, appreciate it.
I go in for a job interview tomorrow for a warehouse job, hopefully paying more than my job. We shall seeeeeeeeee!!!
Oh, and I get my swap done this week!
MY EBAY AUCTIONS
