2000 echo wont run - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2009, 07:17 PM   #1 (permalink)
View rlwillard's Photo Gallery
2000 echo wont run
this car has 297000 miles and has been great. Last week parked and now wont start. I have spark and fuel but does not run. It hit as it turns over, tryed a few things like compresion is about 90 to 95 per cylinder,fuel pump is pumping, put in a set of plugs but had no effect. Is there a way to check crankshaft and cam sensors ??? or am I looking in the wrong direction.
thanks for any help
rlwillard is offline   Reply With Quote
Old 05-24-2009, 06:59 AM   #2 (permalink)
Half a Bubble Off Plumb
Yaris Hilton's Avatar
View Yaris Hilton's Photo Gallery
Smile
Sure you have adequate cranking voltage? Is it cranking slower than normal?
Yaris Hilton is offline   Reply With Quote
Old 05-24-2009, 04:26 PM   #3 (permalink)
engine turns over good, not able to get any codes with scanner either. I sprayed a shot of starting fluid in air box last night and motor ran for about 3 or 4 sec. then its back to nothing.
Old 05-24-2009, 04:35 PM   #4 (permalink)
Smile
I was going to post again and suggest trying exactly that this morning, but had to run to church. That suggests a problem with the fuel. Gas with ethanol in it will separate into two phases if it gets just a little bit of water in it. The bottom phase in the tank is mostly alcohol with some water, and your engine won't start on that. I'm suspicious something like that may be your problem.
Old 05-26-2009, 07:49 AM   #5 (permalink)
View Dake's Photo Gallery
Sounds like either bad gas or not enough. Is it possible the fuel pump is not putting out enough pressure anymore?
If there's water in your gas, you may try buying some Fuel Dry or some other additive designed to clean it up.
If the fuel pump has been slowly dying you would have probably noticed the car get sluggish before now.
Dake is offline   Reply With Quote
Old 05-26-2009, 02:23 PM   #6 (permalink)
Smile
Fuel drying additives are generally alcohols. If the alcohol has separated from the gas due to water, it'll be hard to add enough alcohol to get it back in solution with the gasoline. May require draining.
Old 05-26-2009, 07:07 PM   #7 (permalink)
not sure what happened , but car started yesterday as soon as i hit the switch. I drove it around all day. Started and stop car several time with no problems. I am sure problem will return soon ??? doesn't this have to be something electricial
Old 05-26-2009, 09:59 PM   #8 (permalink)
Smile
You might have pulled enough of the separated fuel out of the bottom of the tank to start sucking good gas into the pump, if the bad gas theory was correct.
Old 03-15-2010, 06:02 PM   #9 (permalink)
Problem with Echo is back, car would not start. Pulled crank sensor out and checked ohms. its only reading 1.3 on gauge. Cleaned sensor up put it back in and car started right away. I can not remember for sure but thinking I read some place it should be 7 to 8 for sensor, anybody have any idea what it should be reading.
