Rear Disks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2009, 10:39 PM   #1 (permalink)
DILLIGAF?!
MahTercel's Avatar
View MahTercel's Photo Gallery
Canada Rear Disks
Hey folks, rear disk conversion for an 05 echo, what are my options if any. Thanks!
-Steve
MahTercel is offline   Reply With Quote
Old 06-21-2009, 02:49 PM   #2 (permalink)
View EdgarTRD1.8's Photo Gallery
Men I'm working in one kit that will fit Corolla, Echo, Yaris, Scion, using the Corolla XRS rear calipers. I'm making some research and a prototype to test. I hope will selling it between $225 to $250 depending the material costs. The kit will include rear drilled discs, XRS calipers, the brackets to get the calipers, and the pads. I need a couple of months to develop the product. I'll be updating the process. Hope you guys like it...
EdgarTRD1.8 is offline   Reply With Quote
Old 07-06-2009, 10:10 PM   #3 (permalink)
on full afterburner
Gameroom cash: $1349697
good to know.
Old 07-07-2009, 03:32 PM   #4 (permalink)
I'm building too an Intake Manifold with the throttle big port to put the 1zz throttle without any air restriction an is shorter than the stock manifold. I'm finishing one to test it on Dyno with the stock TB and a 1zz TB to view the gains, Stock(stock) vs the Intake Manifold with stock TB vs the IM with 1zz TB. Before this month end I'll showing the results and if are good, I'll make some Custom here in P.R. then to other countries.
Old 07-08-2009, 05:03 PM   #5 (permalink)
View LilToaster's Photo Gallery
I have my rear disk all mocked up myself too, Just waiting to get my brackets CNC'D. A very simular setup to EdfarTRD setup except no cross drilled yet.
But as of right now i haven't been able to find a conversion kit yet.
LilToaster is offline   Reply With Quote
Old 07-08-2009, 05:14 PM   #6 (permalink)
Which disks and caliper you used? Im planning to use the XRS because is for sale to particulars and I want they haven't any problem with the post-sale. I tried to take a level, modern Yaris with modern Corollas rear calipers, then if they need to buy, can do it. I can make it for example with the Corolla 91 but some people dont like because the calipers are from an old car blah blah and I decided to make it with the 2003-2008 XRS calipers.
Old 07-08-2009, 06:31 PM   #7 (permalink)
I ended up using the XRS setup due the fact that my friend work's at Toyota and I managed to get them at his cost and such. I wanted to use the newest platform as possable to to the fact that ABS was on the Corolla's and also with the Echo to.
