2002 Echo Not Starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2009, 03:38 AM   #1 (permalink)
View grenda1's Photo Gallery
Echo has been running beautifully, until a few days ago, it refused to start.
I've changed the plugs, checked for spark, injectors are pulsing, changed the battery, starter motor is turning over, compression is 50-100-100-100 roughly, fuel pressure is 40-50 psi.
Any ideas would be greatly appreciated.. I am completely stuck on what to check next.
P.S Someone mentioned a camshaft position sensor recall, does this include 2002 echos???
grenda1 is offline   Reply With Quote
Old 06-06-2009, 05:23 AM   #2 (permalink)
View 05DCLB's Photo Gallery
I think checking for any codes is next. 50 PSI is not good, but it should still run on three.
05DCLB is offline   Reply With Quote
Old 06-07-2009, 03:58 AM   #3 (permalink)
Thanks for your reply, I checked valve clearances today, everything was in check. Ended up short circuiting the fuel relay and draining the fuel.
Put some some new fuel in it, purged the injectors and let it flush through for a bit, and it started up no problems..arhh.
So yeah, just bad fuel it seems?
Old 06-09-2009, 01:25 PM   #4 (permalink)
Half a Bubble Off Plumb
Yaris Hilton's Avatar
View Yaris Hilton's Photo Gallery
Smile
The recall I got on my 2001 Echo was for the crankshaft position sensor. Don't know what range of Echos was covered by that.
Wonder what's up with that one cylinder being down on compression?
Yaris Hilton is offline   Reply With Quote
Old 06-10-2009, 06:56 AM   #5 (permalink)
jambo101's Avatar
View jambo101's Photo Gallery
What does the plug look like on that 50psi cylinder?Could be a broken ring or valve but shouldnt prevent the car from running
jambo101 is offline   Reply With Quote
Old 06-10-2009, 08:59 AM   #6 (permalink)
Smile
Did you try the old trick of squirting a little oil in the spark plug hole to see if it brings the compression up?
