Bolt Broke In Crossmember!!!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-22-2009, 10:26 PM   #1 (permalink)
View J3r3my590's Photo Gallery
Hey all
I have a 03 echo and i had to replace both front ball joints and stabilizer links, which involves replacing the entire lower control arm for the new ball joints (if anyone was wondering), and it jsut so happen that a bolt coming from the lower control arm bushing into the subframe broke, and is no stuck in the threaded side with no access to it at all! so i just got home from work screwing around with it, and ended up cutting the old lower control arm out however the last half in of the threaded bolt is in a blind hole.... therefore im just wondering if anyone had any ideas, and also if anyone new roughly the price of a new crossmember or subframe as some would call it might be? as toyota's parts department are not open at the moment...
thanks guys
J3r3my590 is offline   Reply With Quote
Old 08-08-2009, 01:15 AM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $398685
View RningOnFumes's Photo Gallery
Hope you you've settled your problem...
Did you try a local junker to see if you could transplant the part-- might be cheaper?
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 08-10-2009, 08:49 AM   #3 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
car-part.com look for engine crossmember I saw as cheap as $60.00
new you're looking at $1328.20
Stevo_Echohb05 is offline   Reply With Quote
Old 08-10-2009, 12:49 PM   #4 (permalink)
on full afterburner
Gameroom cash: $1349697
Wish I came across this thread earlier!
Take the bolt (or whatever's left of it) to your local Brafasco and tell them what you're using it for and they should be able to get you a perfect matching replacement.
