Its possible for it to be the cable. Has the clutch pedal been feeling normal? If the pedal feels soft or doesn't return to the top of its travel, check the slave cylinder. Its mounted to the front of the trans. Have someone push the clutch pedal while you watch it. If only moves a little or not at all, suspect either a leaky slave cylinder, broken fluid line or bad slave master cylinder.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door.  New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
