Originally Posted by echo fan
I just paid a mechanic to clean corrosion from the filler neck of the gas tank of my 2005 Toyota Echo to resolve a check engine condition. This did clear up the error condition however I'm thinking I may now have a future problem of premature failure of the fuel filter or other issues with the fuel system.
I read your description. Obviously the "mechanic" is incompetent and should not be hired again.
Am I going to have problems with my fuel filter. It's inside the gas tank so it won't be easy to fix.
That is quite possible. Any particulates are hard on the filter.
Should I drain the tank and replace the filter.
I would if I were you. My first move "out of the gate" would be to buy some P'blaster rust remover/bolt loosener and spray any fasteners which hold the tank into place. Do so several times, avoiding undercoating, so that the fasteners are easy to remove.
What will this cost me?
I don't know.
Should the mechanic pay.
That's for a Judge to decide. I doubt that you'll collect.
You could ask the Mechanic to "make it right". Barring that, in this economic climate, they're going to starve.
Gene
