The maintenance requred light works on a timer triggered by your mileage. It starts flashing at about 4500 from when you LAST RESET the light and stays on after 5000 miles. The light isn't smart enought to know that you changed it before the 5k so you will need to reset it. IF you had it done, they may have forgotten to reset it and I do believe you can reset it even before it comes on.
The maintenance light is not connected to the OBDII port and you can not reset it from there.
1. Set key to ON and put your trip meter to Trip A.
2. Key in ignition back on ACC.
3. Press and hold the trip reset button while simultaneously twisting the key to ON (don't start the car).
4. IF it works, you'll se the trip meter start counting down dashes that appeared, once they all disappear, you'll see 0000000 across and the light should have turned off.
*notes, it's either the Trip A or just the regulary trip. Check your Manual for more info.
Once it's reset, the light will come on again after another 4500 miles.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
