08-24-2009, 07:40 PM
#2 (permalink)
RAM-Driver
First of all -ENVY- ... we don't have diesel models here. Just a SWAG but that looks like a vacuum line, the way it molds into the combustion air stream behind that pot. If you pull the white plastic cylinder out of the rubber line and blow into it, you'll likely find it'll go one way, not the other. Try reversing it and connect it all together. My guess is it's there to pull a small vacuum for, perhaps the HVAC air doors or even ignition timing advance. Does the other end of the rubber tube end at the injection pump or the firewall? Be sure to let us know the outcome
2000 Echo, 200,000kms, aftermarket cruise control (AudioVox CCS-100), Intelligent Battery Guard (CTC), Sirius Satellite Radio, Scangage II, Garmin GPS, synthetic engine and gearbox lubes , Silicone Brake Fluid, Power Steering belt removed, delighted with the "tiny perfect car"
