Noisy A/C Clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2009, 12:25 PM   #1 (permalink)
View Targis34's Photo Gallery
Canada Noisy A/C Clutch
So far just reading here has helped with most of our 01 Echo's small problems but this ones totally whacked.
Hope I can explain it right so here goes.....
If I turn the heat directional controls to defrost and the fan on high, a/c button OFF, The a/c clutch will engage and start squeeling. It might be the belt making noise but I need to know if the a/c clutch is operating properly. It seems to me to be wrong......any ideas??
Mike
Targis34 is offline   Reply With Quote
Old 08-23-2009, 09:39 PM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $136123
View Hajoca's Photo Gallery
Defrost mode uses the A/C to dry air blown onto windshield to clear it of fog / condensation faster to allow the driver to maintain visibility.
It does not matter if it is using fresh or recirc air.
Squeeling noise is not good. How many Kms ?? Belt may need replacement. If belt is new, spray some water onto belt while squeeling, if it goes away, check belt tension.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 08-25-2009, 06:14 PM   #3 (permalink)
Canada
I was also having a stalling problem at low speed so I decided to clean the OCV circuit filter. To do that I had to loosen the gennerator and belt to get the bolt holding the filter out. When I put it back on I tightened the belt more than it had been and the squeeling seems to have gone away. The belt hadn't felt loose but it seems to have worked.
My stalling also seems to have improved..........
