Yaris - Tips and Tricks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2009, 05:40 PM   #1 (permalink)
View jojo2008's Photo Gallery
Hi
Just bought my Yaris a few weeks ago. Had another stereo fitted and since then the Seatbelt alarm does not work anymore (Good/Bad - I like it).
I noticed that the before starting fitting the guy fiddled with somethings eg. Key, Spedometer and have searched around and THINK that he may have disabled the alarm with his fiddling.
1. Does anyone know the way to Switch the Seatbelt alarm back on ?
2. Does anyone have reference to any other Trick things that can be done ?
3. Is there a way that ALL windows are rolled up when key is taken out of the ignition ?
Thanks
JoJoZep
jojo2008 is offline   Reply With Quote
Old 08-31-2009, 10:29 AM   #2 (permalink)
RAM-Driver
denman's Avatar
View denman's Photo Gallery
Canada
Originally Posted by jojo2008 View Post
Hi
1. Does anyone know the way to Switch the Seatbelt alarm back on ? ... I'd leave it disabled as one less nuisance noise
2. Does anyone have reference to any other Trick things that can be done ? ..... I installed a cruise control kit in my Echo and Sirius Satellite radio and am very pleased with both
3. Is there a way that ALL windows are rolled up when key is taken out of the ignition ? ..... unlikely possible unless you have power windows
Thanks
JoJoZep
and BTW welcome to the forum, .... someone smarter than me will likely chime in with some better answers
2000 Echo, 200,000kms, aftermarket cruise control (AudioVox CCS-100), Intelligent Battery Guard (CTC), Sirius Satellite Radio, Scangage II, Garmin GPS, synthetic engine and gearbox lubes , Silicone Brake Fluid, Power Steering belt removed, delighted with the "tiny perfect car"
denman is offline   Reply With Quote
Old 09-22-2009, 09:32 PM   #3 (permalink)
View 06yaris's Photo Gallery
Maybe he was reseting the maintance minder
06yaris is offline   Reply With Quote
Old 09-24-2009, 11:11 AM   #4 (permalink)
View thetickis2slow's Photo Gallery
The TRD rear anti-swaybar and a set of 16" rims and tires improved the fun factor on mine.
The Yakima roof-rack made it more useful. We tookit camping up in B.C. with 2 bikes on top and then to Morro Bay with kayaks.
Cat-back exhaust helped a little with power but I don't know the actual numbers. Enjoy!
thetickis2slow is offline   Reply With Quote
Old 09-26-2009, 08:37 AM   #5 (permalink)
View Dake's Photo Gallery
Yeah, I'd say just leave that seat-belt alarm disabled. That's the most irritating thing on the Yaris. I always wear a seatbelt, but if you don't put it on quick enough for the car it will keep beeping at you even after you've clicked it.
Dake is offline   Reply With Quote
Old 11-12-2009, 09:38 PM   #6 (permalink)
View echo987's Photo Gallery
There is an electrical plug that runs up to your seat belt button that tells your car if you are belted. He probably unplugged it. Look under your seat and see if you have a wire unplugged. Get rid of your green dash lights and go white by removing the little green covers on the dash bulbs. it takes about two minutes. I think it looks a lot better. Windows rolling up when you turn the car off is a custom Job which a custom shop could probably hook up with the right know how and the right amount of money.
echo987 is offline   Reply With Quote
Old 11-27-2009, 11:36 AM   #7 (permalink)
Half a Bubble Off Plumb
Yaris Hilton's Avatar
View Yaris Hilton's Photo Gallery
Smile
Unplugging that wire under your seat might disable your air bags as well. I don't know about the driver's side, but the passenger side air bag turns on and off depending on whether someone's sitting in the seat.
Yaris Hilton is offline   Reply With Quote
Old 11-27-2009, 12:29 PM   #8 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
I don't think you can disable the seat belt alarm, he may have tapped into a wire he wasn't supposed to
the seat belt warning light works with the belt not the buckle, that plug is probably hidden inside the B pillar
Stevo_Echohb05 is offline   Reply With Quote
