11-16-2009, 07:21 PM
#5 (permalink)
RAM-Driver
I second the recommendation to get a code scanner esp since they can be used on other cars newer than 1996. OORRRR, ... if you wanna go nuts with the gadgets you can get the ScanGauge ($180 give or take) which plugs into the scanner port and reads the codes but also gives you the rest of the gauges on a display, eg tach, temp, mi/gal (now), mi/gal (average), and a half-dozen or so other parameters as you wish. Lots of fun and using will inevitably lead you to better fuel economy if you want that, ....
2000 Echo, 200,000kms, aftermarket cruise control (AudioVox CCS-100), Intelligent Battery Guard (CTC), Sirius Satellite Radio, Scangage II, Garmin GPS, synthetic engine and gearbox lubes , Silicone Brake Fluid, Power Steering belt removed, delighted with the "tiny perfect car"
