need help cluster problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2009, 10:27 AM   #1 (permalink)
View marmus74's Photo Gallery
Canada need help cluster problem
hello guys
yesterday i bought 2000 toyota Echo which have problem with the speedometer .the car have 208569km on it and like to know if i change the cluster and put the used one will it show same kilometer which is in my car or diffrent kilometer what ever is in the other cluster?
Thank you
marmus74 is offline   Reply With Quote
Old 09-27-2009, 11:42 AM   #2 (permalink)
RAM-Driver
denman's Avatar
View denman's Photo Gallery
Canada
Originally Posted by marmus74 View Post
hello guys
Thank you
You should be OK with a swap as these are pretty much Leggo plug'n'play, with big color-coded block terminals so you can't get the wiring wrong. What's the speedo doing wrong?
2000 Echo, 200,000kms, aftermarket cruise control (AudioVox CCS-100), Intelligent Battery Guard (CTC), Sirius Satellite Radio, Scangage II, Garmin GPS, synthetic engine and gearbox lubes , Silicone Brake Fluid, Power Steering belt removed, delighted with the "tiny perfect car"
denman is offline   Reply With Quote
Old 09-27-2009, 01:29 PM   #3 (permalink)
Canada
well i when i bought the car nothing is working in the speedometer.dont know what is wrong the previous owner told me that the cluster need to be replace.so i like to know the kilometer reading is it saved in the cluster or ecu?some one told me if i get the cluster from scrapwayd what ever are in the cluster i will get that km reading.is that true?
Old 09-27-2009, 03:47 PM   #4 (permalink)
RAM-Driver
denman's Avatar
Canada
I do believe the odometer count is stored in the speedo and does display whatever it recorded in its previous environment. Could be wrong as that PCM has nearly everything controlled within its evil empire.
