radio light problem for echo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2009, 06:56 AM   #1 (permalink)
View loveday's Photo Gallery
I hope somebody can help me with this. Recently my radio display light shuts off whenever I turn my headlights on. This is the factory installed radio for a 2003 echo. The light comes on whenever I turn my headlights off.
Any idea why it would do this?
loveday is offline   Reply With Quote
Old 10-20-2009, 07:22 AM   #2 (permalink)
View Dake's Photo Gallery
Weird. The radio back-lighting lowers in intensity when the headlights come on since it doesn't need to be as bright at night, maybe a relay is bad, so the lights just shut off all together?
The radio itself still works when you turn your headlights on right?
Dake is offline   Reply With Quote
Old 10-20-2009, 07:32 AM   #3 (permalink)
Yes the radio still works fine. Just all the lighting shuts off when the headlights come on.
Something else I noticed, the lighting for the speedometer and tachometer always resets to the dim setting after turning on the headlights. I used to always have it set to bright. I can still set it to bright after I turn on the headlights but it will reset if I turn the headlights off and back on.
Old 10-20-2009, 09:58 AM   #4 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
Normal operation-
I think this is used when you drive down a long dark highway, the brighter light shrinks your iris to help you see better at night.?
Stevo_Echohb05 is offline   Reply With Quote
Old 10-20-2009, 12:29 PM   #5 (permalink)
Originally Posted by Stevo_Echohb05 View Post
Normal operation-
But it's only just started doing this. I've had the car since it was brand new and it suddenly had these weird problems yesterday.
Old 10-20-2009, 02:48 PM   #6 (permalink)
I'm officially stupid now. I found out the problem and it was the dash light dimmer switch set to the dimmest setting. Apparently I must have changed it when I applied armorall yesterday.
Old 10-21-2009, 11:34 AM   #7 (permalink)
AWESOME!
Sometimes the simplest and all that. You're not stupid until you tear the dash apart and open up the radio to try solving the problem!
