Originally Posted by thebarber
forest city surplus ftw!
Tried that, didn't work.
Went to wreckers and obtained relay--wrong one though.
Went to the dealership for the part number and they gave me a number for an updated relay for fog lamps--seems they're always upgrading--gave me a schematic for exactly where it goes too--wo-hoo!
Went back to the wreckers. Bugger!--can't get to it. It's located on right side of the fuse panel and the access door is only large enough to get at the face of the panel. Tried reaching under the dash but very difficult to do when car bodies are resting on the ground and they're placed so close you can't open the doors all the way. I concur #%&* the wreckers.
Went back to online shopping. Accidentally found a TSB on the relay number the dealership gave me. Apparently a problem with the A/C compressor clutch relay is causing problems with A/C not working across all Toyota's models the fix is to upgrade the relay. My A/C didn't work as good as it should have the past two summers--it should have as a pothole mishap had the driver front wheel drop into it and land the frame of the car on the asphalt and one of the things replaced was the A/C condensor. Perhaps the A/C problem I'm having is due to the relay? Anyway the upgraded relay I need for the fog lamps is the factory relay for the A/C--cha-ching! Found and removed this very easily from the panel under the hood. Bugger, can't find where the slot is. I have the diagram and I can reach under the dash panel and feel the side of the fuse panel but can't get this thing in.
Gave up and went to the dealership to have them put it in. Took them quite a while--they had to find the resident electric guy as nobody has ever had to deal with fog lamps on any vehicle there before. Awesome, they did me a solid and plunked it in at no charge!--wasn't expecting that.
Turn the switch on and they don't work. Apparently they will only come on when the headlights are on. I was hoping I could dumb down the lights to daytime running lights and turn on the fogs for those zero visability days, at least that's what I thought the purpose of foglamps were so you could see the road not the fog. Oh well, I will content myself with the fact that they work. Am dumbing down my headlights though to standard bulbs this seems a workable solution. Should anyone have any better ideas on this please let me know.
