first car, a Toyota Echo. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2009, 08:56 PM   #1 (permalink)
View AbitibiEcho's Photo Gallery
Canada first car, a Toyota Echo.
I just bought a toyota echo, 250 000km. It is a 2001, i paid it 1200$, i think i could not let pass this deal.
But the gaz mileage is very bad, my tank is almost empty and i got 350km on it, it is mostly city driving but still bad. the guy that sell it to me said one of the oxygen sensor does not work. i know its controling gaz/air mix and all, but can it affect gaz mileage that much ??
AbitibiEcho is offline   Reply With Quote
Old 11-14-2009, 09:18 PM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $398685
View RningOnFumes's Photo Gallery
Hello there, Welcome to TN.
Yes. You will need to look into getting that part fixed, it is a major component to your low mileage. That is a very good deal on your car, fixing this minor issue should give you a lot more miles!
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 11-14-2009, 09:29 PM   #3 (permalink)
thanks, i'll check this out.
Old 11-15-2009, 01:15 PM   #4 (permalink)
Bombcatter's Avatar
View Bombcatter's Photo Gallery
Canada Should get double that
I've gotta Echo Hatch 05 and it gets 624km from full to empty (flashing)...so you really gotta look into that. Enjoy the new ride aside from that problem.
Bombcatter is offline   Reply With Quote
Old 11-16-2009, 06:31 PM   #5 (permalink)
RAM-Driver
denman's Avatar
View denman's Photo Gallery
Canada
Hey Abitibi, .... my welcome also to the forum, .. lucky you to have one of these as your first car, .... if you've got a sensor out there should be a "check engine" light showing on your dash display. An OBD II scanner (aka code reader) will tell you which sensor is faulty. The others are correct in that if it's an oxygen sensor that's faulty then the engine will not get the correct fuel mixture. I have changed O2 sensors myself but they're usually nasty jobs involving under-the-car work and VERY tight large fittings. De tout facon I look forward to seeing you on this forum as other aspects of the car come to your attention. There's even a sub-forum for bragging about fuel economy !!
2000 Echo, 200,000kms, aftermarket cruise control (AudioVox CCS-100), Intelligent Battery Guard (CTC), Sirius Satellite Radio, Scangage II, Garmin GPS, synthetic engine and gearbox lubes , Silicone Brake Fluid, Power Steering belt removed, delighted with the "tiny perfect car"
denman is offline   Reply With Quote
Old 11-16-2009, 08:35 PM   #6 (permalink)
thanks denman, i just look in the maintenance document of the car and i found a document showing the bad sensor, it is the Bank 1, Sensor 2, the 4 wire sensor.
I got it remove and i bought a new one but the tread in the exaust pipe are almost all gone now. I think i am gonna weld it on the pipe...
