Echo won't shift from park, no hazards, no radio, no turn signal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2009, 02:02 PM   #1 (permalink)
View rwade's Photo Gallery
My husband replaced my daughters water pump in 2002 Echo. Now the car won't shift from park. Also no turn signal, no hazard lights, no radio, no heater or AC fan. Is there a reset switch or something? Any help is greatly appreciated. Also it starts and runs fine.
rwade is offline   Reply With Quote
Old 11-16-2009, 06:39 PM   #2 (permalink)
RAM-Driver
denman's Avatar
View denman's Photo Gallery
Canada
The WP replacement SHOULD have no effect on the other components, but there is a power distribution center under the hood (mine's on the drivers side fender) with fuses and relays that cover those components. I'd pull the cover there and see if all is well. Failing that a fusible link failure might explain the wide variety of issues. If so get back on here and one of us will have a squint at the wiring diagrams and lead you toward a solution,
2000 Echo, 200,000kms, aftermarket cruise control (AudioVox CCS-100), Intelligent Battery Guard (CTC), Sirius Satellite Radio, Scangage II, Garmin GPS, synthetic engine and gearbox lubes , Silicone Brake Fluid, Power Steering belt removed, delighted with the "tiny perfect car"
denman is offline   Reply With Quote
Old 11-19-2009, 08:11 AM   #3 (permalink)
Thank You so Much!!! It was the alternator fuse in a red box attached to the battery. Works great now!
Old 12-09-2009, 07:44 PM   #4 (permalink)
View Echo23's Photo Gallery
rwade i was wondering how u got at the red box i think my altenatore fuse blew but i cant seem to get at that red box bunch of wires in the way did u disconnect it.
Echo23 is offline   Reply With Quote
